Heater Cable?
Heater Cable?
81laredo
Idyllwild, CA
1981 CJ7 Laredo as built, 1952 Pontiac Sedan Delivery, 1955 Thunderbird, 1958 Airstream, 1996 Tahoe 4X4, 1982 Newell Coach, 1957 Cabin in the Woods what will I work on next?
I found that the Fresh Air Vent Cable is separated and not functional. I have found the 3 that are in the Dash but this one does not appear to be available.
Any ideas? this is the one that goes to the box below the dash from the vent linkage.
I just replaced mine today. I bought the long one from Quadratech. I think it was something like $14.
It was too long and I wrapped the cable around a screwdriver shaft that was the same diameter and it worked.
Thanks guys!
Yes, it is the discontinued and not available part on the far right. I found one at J&W Auto Parts (Jeep Wrecking Yard) in Antelope, CA. It was $14.00 used and in good condition, problem is that there was another $13.00 for UPS. Anyway the part is good and now I have it in the CJ7 .
I should be able to drive the CJ7 this weekend after the Howell EFI up-grade.
