HEI distributers
northboundcj5
OK guys,It's been quite a while since I've posted....I've been in the process of replacing my AMC 304 V8..If you look at my past postings it would get you up to speed on the whole sad affair..but in a nutshell my CJ put me on the side of the road in placerville and thru the goodwill of a brother jeeper I was able to get out of a dangerous situation on a busy freeway and then I called a tow truck to get me home 2 hours away.
OK that all brings me to the point I would like to share and hopefully receive some input from you guys...
My CJ was running perfect ..I mean smooth. I had recently done some mods ..includeing replacing my dist. With a HEI
Type from 4WD parts..anyway I had ascertained that my timeing chain had broken but it turns out that my can gear was ground off..which of course would give the same results ...loss of timing.. OK well now I am replacing the motor and I am afraid that the dist. (Which by the way is a beautiful looking piece of equipment) will do the same thing to my new 2,000 dollar engine..the guy at 4wd parts told me they were having trouble with them but would not elaborate on the exact problem..so I hope you guys get the general drift of what I'm asking...thanks in advance...
