HELP! CJ Won't Idle and is Trying to Start in ACC On Position!
ThisGuyUKnow
Full Time Jeeper
- Featured
- 2
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Ok so my T-5 went out and I elected to do an AX15 replacement. I drove the CJ in fourth gear(the only one that worked still) to the place where I have been working on it and it idled fine. I spent the last couple weeks swapping in the AX15 and in the process the only things I had to change electrically were the leads for the reverse pickup on the tranny and the starter from the DOnor required an extra line to allow it to fire the starter (I just wired this directly to the same line as the original starter).
I first ran that extra lead to the acc on line but the truck wouldnt stay started once the engine caught. so I ran straight to the same lead that originally connected to the starter and the engine would start and stay running so long as i depressed the gas. once I let go of the gas it would just die. I thought maybe it was just cause it was cold but once I warmed it up to operating temp still would just die. My first thought was fuel? but I checked the output on the fuel filter and it squirts real good and the jets are squirting strong as well.
The only thing I can think of is it must be something electrical that is preventing it from idling right?
Well to add more grief I pulled the leads of the solenoid and cleaned them. I had left the key in ACC on by mistake when I did this and when I put it back together the lead on the top right caused the starter to fire. Now if you turn the key to ACC on the jeep starts. Not cool!
I traced the engine harness from the solenoid all the way to the control module and fire wall and there are no crossed/melted wires on the engine harness(I pulled every inch out of the black plastic --not fun!) so the problem must be under the dash somewhere?
What should I do? I am in desperate need of a car right now so I would like to be driving my CJ ASAP. Is the problem most likely electical? If so I can just tow to the local automotive wiring shop and have them do it. I cant see how the tranny would cause this since the engine isnt computer controlled like modern cars.
or if the crappy idle is now indicative of a problem elsewhere?
