HELP! CJ Won't Idle and is Trying to Start in ACC On Position!
ThisGuyUKnow
Full Time Jeeper
- Featured
- 7
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
I dunno this cj has been nothing but trouble since I got it. I just spent almost three weeks replacing the dang Transmission just to come out on the othr side worse off. I am thinking it may be time to throw in the rowell and get a newer wrangler or XJ.
welcome to the wonderful world of CJs, but don't do that. we'll help you fix it, how did you wire up the hei? did you use some wiring for the motorcraft module? if so you most likely aren't gettin a full 12v to the dist. thats not to say that there also isn't
in the carburetor. but if you rewired it some and it will idle after that i suspect that you still have a small wiring issue, along with junk in the carb.
