Help diagnosing an engine problem.
stoney bones
This has been going on forever and it is driving (lol) me nuts.
Started very shortly after purchasing jeep. It will be running seemingly fine, then what seems to be randomly, the motor starts to bog down and want to stall.
Doesnt matter if vehicvle is warmed up or not.
You can hold the throttle at say 1/3...the motor starts reving up smoothly..hits somewhere (im guessing) around 2000or so rpm then its like the gas cuts out...all the way down to an almost stall. sometimes without moving the gas pedal it will jump back up to an idling rpm (all still with foot help at 1/3) then it ill climb smoothly and repeat. It will usually stall unless you kind of bounce your foot on the pedal and you can work the rpms back up.
I will drive it around the property like this for an hour trying to figure it out...get mad park it a few days then when I come out again it will work fine again...for a random amount of time, like hours, or days, then it goes back into it.....
When this first started happening I got on here and learned of the MC2100 upgrade....I thought it was my carb so I switched out.
Ran fine at first..then right back to the same problems.
I took the jeep to a friends dad who is a mechanic. I had him go through the carb, give it all a tune up. He never duplicated my problem. Gave it back to me and it ran great for a couple days. Parked it for about a week and it was the same old same old all over again.
Ignition is all new. I had it checked over as well as having the timing adjusted.
new fuel filter...the fuel pump is working (at least sometimes)..i can tell that much...
What can I check now? This kills me...All I want to do is drive my CJ!!!!
edit to add:
just the other day I was driving around well over an hour flawlessly....then all the sudden it started doing it again...started bouncing the throttle to keep it running like always and limped it back to her bed....before I even got to park it, it just started running normal again...all the way from
to golden and back again within a matter a mins...normally takes days or weeks.....i dunno if that helps at all.
and i have changed out the gas multiple times...been through 4 tanks of gas (at least) with this problem persisting the whole time intermittently. I do use stabil when I know it will be sitting any amount of time.
edit to add:
