Help! I know i'm forgetting something!
wolfclan
Charleston SC
86 CJ7 258 AMC20(for now) 5spd mostly factory.....but hey, I've only had it for 3 months!
So after tearing down my AMC 258 i6 / 4.2l and finding a cracked piston skirt, low comp on 3 cylinders and 2 burnt valves, I started on a major overhaul. I have just gotten the 4.0 head, added a header, Clifford intake, and Weber 38 carb. :DWithout going crazy, what else do I need to do? Flow Kooler water pump? upgrade the stock motorcraft ignition? I'm in coastal SC, so I'm limted to fairly flat roads and trips to the hunt club for a little muddin'. Jeep also has a 5 speed manual tranny and 273 gears in an AMC20 diff, running on 31's with 0 lift (for now!)
I do not want to be stupid, just solid an reliable with this build. Any thoughts and comments are much appreciated.
So after tearing down my 258 and finding a cracked piston skirt, low comp on 3 cylinders and 2 burnt valves, I started on a major overhaul. I have just gotten the 4.0 head, added a header, Clifford intake, and Weber 38 carb. :DWithout going crazy, what else do I need to do? Flow Kooler water pump? upgrade the stock motorcraft ignition? I'm in coastal SC, so I'm limted to fairly flat roads and trips to the hunt club for a little muddin'. Jeep also has a 5 speed manual tranny and 273 gears in an amc 20 diff, running on 31's with 0 lift (for now!)
Maybe a mild cam upgrade.:) As to which one someone with more experience in building motors needs to chime in.:chug:
No need to go with a high dollar waterpump. You will install it and find out your 4.0/AMC 258 i6 / 4.2l runs hot anyways.
An ignition upgrade is almost a must...the stock junk is just that. I did a TFI upgrade on my inline 6 using all Ford parts and it is a huge difference. I didn the same TFI upgrade on my 401 with the same results. Best part is you are replacing stock parts with better stock parts.
Cam selection can be interesting. I used flat pistons on my build to bring up compression and used a 262 duration cam with higher lobe profile for my CFM needs. A 262 will be more then you need however...my build demanded it.
If you can get away with it in your area, I would highly recommend de-smogging it also.
No need to go with a high dollar waterpump. You will install it and find out your 4.0/4.2 runs hot anyways
Thanks. If its going to run hot anyways AND I currently don't have a fan shroud on the stock clutch/fan package, should I spend the $100 on a shroud or go for the dual electric fan upgrade?
Some people like the electric fans over mechanical clutch fans....I've never used one. What I do know is if you use the mechanical fan, a shroud is a must.
The AMC 258 i6 / 4.2l tends to run a bit hotter with the 4.0 head upgrade. I've used Water Wetter with good success. I also louvered the hood to vacate heat.
