Help identifying a clutch and flywheel.
Zech
- Lynnwood,Wa
- 1974 CJ5 Buick 231 conversion, T14 trans, Dana 20 transfer case, D30 front, D44 rear. Unsure of gearing but who rig is stock so I'm assuming stock.
I am in the process of changing out the clutch due to a horrible chatter and grating sound when letting it out. Pulled everything apart and the throwout bearing was completely destroyed. Everything else looks ok, but I figured I would replace everything while I have it all apart. I can not find the clutch the goes with this flywheel? This is a buick 231 conversion and the motor casting id's it from 1979. The flywheel is raised in the middle. The machine shop says he has never seen a flywheel like this but looked it up in a catalog that Buick did have raised and flat wheels in 1979. I have struck out all over the place and not sure if I need to find a different flywheel and just start from scratch? This jeep has been rigged together to no end so It wouldn't surprise me if this was something he pulled off anything he could find in a junk yard. Thanks for any help.
Zech I posted some pics of the flywheel and the pressure plate with the surface the clutch disc rides on. Its recessed into the pressure plate.
