Help me identify these ports on my intake manifold
Flex BT
Chesterfield, VA
1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains
Blue and rust colored.
I believe the 1st is a temperature switch that is screwed into the water jacket of the intake manifold. #2 I would say was a manifold vacuum port, although I have no experience with the Webber. and #3 is the EGR valve, Exhaust gas recirculation, part of the emissions system and not a bad thing to have. I will let you research this one for details as it would take way more time than I have this morning to explain. In the first picture I would say the one on the right used to be a CT switch. It is a temperature activated valve that controls the vacuum to the emissions components and the thermostatic air cleaner. The other one I don't have a clue, specifically, but is taps the manifold hot water for what ever you want to do with it. Coffee warmer maybe??:laugh:
Do any of those have fuel vapor that might be coming out? The worst gas smell is after letting off of a hard acceleration.
I do have a Holley fuel pressure regulator installed and set to 3.5 PSI. Is the #1 temperature switch anything I need to be concerned about?
