Help with rear end
alabamaboy54
And they said the camber was exactly where it needed to be.did they say the camber and castor were good on the front axle
This is my second jeep, and i have had it for a couple of months, im just starting to build it (Basically my new toy). my current tires are a set of new bfg all-terrains, 31x10.5.How long have you had THIS Jeep? Is it your first Jeep? How wide are your tires? A lot of times larger tires will follow road crown more dramatically than skinnier tires due to the large contact patch. Also low caster angle can also cause bad directional stability. My bet would be that the caster is your main issue.
Sent from my SPH-D710 using Tapatalk
Im fairly optimistic in hoping the shims will at least make it driveable, where i can then check the rear tires for any "dogtracking". Ball joints have been checked many times over and wheel bearings are on the list to check just havent been gotten to yetShouldn't be caused by the tires. See what happens with those caster shims installed. I would also check the ball joints and wheel bearings for looseness.
