    Thank you for your support!
Help
Help
granparon2002
Ceres Ca.
2002 Ford Superduty 4X4,66 Mustang,,98 ford Ranger
Hi all, Thanks for making me feel welcome. I have had 4x4 all my life,and that's a long time. I just bought my first Jeep,a 83 CJ5 , a basket case out a field here locally.It has been sitting for about 12 years. The motor is a V6 [Buick I think] and it has a 4SP. Transmission , But the tranfer case is missing. I've been told that the Dana 300 is what came out,but can;t find one locally. Is there something else that will work. Thanks Ron:confused:
Have you check with any of your local 4x4 clubs? What about Craigslist?
The 83 did not originally come with a V6 so someone swapped that in there.
Can you get us information on exactly what Transmission you have?
Hi & Welcome,
I feel your pain.....I have a "project" Jeep as well!:D
Hey CJ; We are trying to figure out the motor, It's a GM with throttle body fuel injection. The transm. looks like a T177-176,according to your drivetrain forum; I couldn't find that numbers,but on plate on the right side of the Transmission . was stamped rgbd 5359389 0920 18. on the left side cast into the case is [top]C260 4203 [below] 16K828067.1. The Transfer Case adapter/tranny mount is round 6 bolt. I hope this helps.as I said we just hauled this thing to the shop and are trying to figure it out. We hope to have operational for hunting season{a month away] Thanks
I can't help on the Transmission but, the 300 is a 6 bolt round pattern, not sure if anything else is through. My guess on the GM 6cly. with tbi would be a 4.3 as thats a popular swap.
