Holley 390 cfm
jeremy5780
I thought I seen a post on here regarding rebuilding/adjusting the holley 390 cfm on a straight 6. But I cannot find it. Any help? I'm running a
offenhauser intake with the 390 4 barrel holley. I have a hard time keeping it running when cold. I have to be sitting inside when I start it with my foot giving it some gas to start, then I must keep it revving up or it will idle down and stall. I keep revving it up for a minute or two to warm it up then it runs and idles fine. If I drive somewhere then let it sit for an hour or so I have to repeat the process of the cold start up. Is this normal or do I need some work? I bought it like this from the PO so I'm not sure what the normal should be? Thanks
