Horn and tach!
Horn and tach!
jeepnmomma
West coast
1986 CJ7 Laredo
Gotta pick some brains again!!! :)
Couple of questions!
1. Horn doesn't work and was wondering whats the best way to test it? How do you get the steering wheel off (its says amc, its a 3 spoke steering wheel) to check if there is a wire cut in it for the horn (like if someone needs to service it also)?
2. The tach isn't hooked up at all! I think its missing some wires. It only has a red, red w/white stripe and orange. Does anyone know what it looks like on the back of one that is all intact? Since I have a fuel injected engine in it now. Does it need a different tach anyway???
thanks for letting me pick! :)
You need a steering wheel puller. Try auto zone.
Well there isn't a black ground wire on the tach!
AND
how would you get the horn button off the steering wheel to get it off? Can't figure out how to get the actually horn button off!
Thank you!!
It is a factory tach and I have a feeling that it was disconnected because it failed.
thanks for the horn info! Have to start testing to see whats going on! I'll just have to use the "silent" horn until I can get it fixed!!!
I use middle finger...
And if that isn't loud enough, I've been known to use gunshots to get someones attention! :D
I am trying to get my factory tach wired up. PO installed a Painless Universal harness in the Jeep. I should be looking for a heavy gauge wire close to my ignition correct? I have the purple "Tach" wire under the dash from the Painless harness but trying to figure out which ignition wire I should use.
got an '85 CJ7 with a dead horn . . . buddy installed a radio and pulled the red wire from the fuse block that comes off the horn fuse (20amp). where does this red wire go in the fuse block? Tried a open terminal - blew the fuse . . .
You can use any switched 12 volt source. Use a multi meter to see which wires are hot and cold when the key is on and off.
The painless wire is purple with a white stripe isnt it? all the others are easy hook ups.
