Horn question
Horn question
228jeeper
Ocean Springs, MS
86 CJ-7, 258, Desmogged, 4 speed T-176, Carter-Weber 2731, headers (no idea what kind), K&N Air Cleaner. Everything else stock as near as I can tell
There is a horn under the hood that will honk when hooked to power but there is no wire running to the steering column and to the steering wheel. You can press the horn cap on the steering wheel but it does not press down. Any suggestions on wiring up a horn in order to get an inspection sticker? Thanks.
does your turn signals work?
reason the turn signal and the horn wire is basically grouped together on the turn signal switch in side the column
or you can get any 2 to 3 wire momentary button and wire the horn yourself
i have seen a house doorbell button in an old chevy before as the horn button
have you been in the column yet?
