Hot Headed
Hot Headed
7D8CJ
Crown Point ,IN
1978cj7 glass tub tilt front end 4.5" Rubicon Express lift 304 DUI Holly truck avenger T150 D20 33's , 2010 Rubicon JKU, 2015 WRX
My V8 CJ runs on the hot side. Thinking about installing an electric fan. What's the best way to go, new aftermarket or setup off a production vehicle?
Any insight would help. Thanx:chug::chug:
When's the last time you had a rod-out done on the radiator and a pro flush on the block?
Bet you use 'tap' water with the coolant.
Do you control the fans by switch or do they work automaticly? What are you using for a sensor?
Thanx, didn't mean to ignore you. Radiator is new and engine is a recent rebuild. I never liked the way my solid fan fits with the radiator so I think elec. fan is the way to go.
As Lump said, tap water is bad. Solid fan or electric, don't use tap water if you don't buy premix coolant
What engine temps are you see'n?
I live in the Mojave and have no over heat issues with a 195* t'stat. I do use a shroud.
Recent rebuilds (under 1000 miles) will run hot until the rings are fully seated and things are broken in maybe 10-15* above what it'll run later.
What's the AMP load/draw of those fans?
Std jeep CJ alternator was 45 amps-
You'll need to upgrade the alternator to keep the battery charge'd.
:notworthy::notworthy:I got my fan setup today off of a '98 Mystique. Mine wasn't in the trunk though. It took some rippin' and tearin' but I got it. Half price day at pick and pull only $27. Thanx :notworthy:
That's a good deal. To test hook up the primary wires GN/WH and GN/BU and the Black Ground wire to your battery to test the circuits and fan motors. Just make sure the shroud is held by someone or otherwise secure. Mine wanted to take off like a VTOL aircraft when I did this test. :rolleyes:
'BB' is running the alternator that she came with when I got 'er, looks to be a GM type. She does have a dual battery setup though on account of the winch that I wanted dedicated power for. Still in all, depending on the temperature the fans are set to engage, they won't run the battery down. On the other hand if they're directly connected to the battery without a switch and runs constantly then it's another story.
