How do I wire a coil on my 74 cj5 W/232?
74gator
mn
74 CJ5 Levi ed. (gator)
Hi I just bought a 74 CJ5 with a 232in itt. the wiring was junk so I cut it all out. I have a push button start hooked up already. I just dont know how to wire the coil. Can anyone help? I have + hooked up to a toggle from fuse box now.
+ side to switched 12v on start (usually the I place one the solenoid). + side to stepped down voltage (ballast when running).
- side to dist and tach.
So I have a toggle going from fuse box to the + side of coil. Do I need to run 1 to the silinoid also?. Caveman language please.
Switched wire to+ of coil dist to - of coil
Thanks. I have it set up and it fires. had to replace the points also. They were melted and not even touching. It still wont start. I think it could be a weak starter or just timing. When it fires the motor stops turning as if the starter sucks. but not sure yet. has anyone delt with this?
How do I? Oil seal
