How to mount the " Best winch ever"
That would be cool but it looks like it will hit the radiator on a CJ.:cool:
i guess if i noticed the links in your post i wouldn't have asked that last question. i don't like to experiment with steering thats one of those things where tried and true works real good for me. if it was known to work good on a CJ7 that'd be great but i don't wanna be the first to test this one
Boy, I was thinking throughout this thread you have to position the fairlead centered but after the pics I'm not so sure. I would mock it up in diff positions and post the pics then let us vote!
You see the one that Gillmore posted in post #6??
well thats the other end of the range.
Mechanically or practically I can see no reason to center the spool. It isn't like what your pulling on is ever centered or that it will ever wind even under a load.:cool:
my passenger signal will be covered the way I do it. I can see why some want that uncovered.
I like the tower in front of the winch IO, you need to put a few light tabs on it.
oh, and to me, I just can't get past that fairlead being so far to the drivers side, Sorry, that is just me. I am kinda anal that way, I know it does not matter mechanically, and it is probably better on the front springs.
Is it on yet :confused:
I should have some pics tomorrow of the fairlead tower/light bar on mine.
Looks great Jokenring, thanks for posting the pics
I like it. Next time you may find it is easier to drill the clevis holes before you weld the mounts to the bumper.:cool:
You just want to take all the fun out of it.
I wanted to, but I had no 3/4 drill bit, got that now
those mounts are an extension of the 1/4 inch brackets to mount the bumper, I cut strait through the square tube and welded the1/4 inch through front and back, then doubled the front and cut it to shape. So you see I kinda was stuck needing to double the steel before drilling. once on I decided it was going be a chore to drill it and I would deal with it late, I can use the receiver for a recovery point till then.
$45.00
  22.5%
