Howell TBI, California smog, high idle...
Tremelune
I just picked up an '83 CJ7 with the AMC 258 i6 / 4.2l motor and the California-CARB-certified Howell JP1 throttle body fuel injection kit. I'm now trying to get it legitimately through smog, and I'm currently held up on a high idle.
It runs and idles well. It sometimes stumbles when warming up, but always starts and very rarely stalls. When warm, it idles at 900-1,000rpm and I need it to idle at 700-800rpm to pass.
The first thing I tried was to adjust the idle screw. When I turned it in a turn or two, idle sped up. When I turned it out, idle stayed at 1,000rpm even with the screw completely unthreaded.
Then I stumbled on this thread which talks about jumping the ALDL to reset the IAC, but it didn't seem to have any effect for me. The IAC did a bunch of clicking until I disconnected it. Idle stayed at 1,000rpm and turning the screw did not lower it. Maybe it only works if vacuum leaks are found...?
Eventually I found some issues with vacuum. After squeezing and plugging and poking, it seems the only way I can get the idle to drop reliably is by pulling the thick PCV/canister line (with a "T") and plugging the inlet with my thumb. The motor then gets a tad bit surgy every now and then, but more or less idles from 700-800rpm. I'm not sure where to go from here.
This system was installed in like 2003, so anything could be wrong, but from what I've read there's no great reason why this thing shouldn't start, idle, and run well cold and hot while passing smog. I'm happy to replace vacuum lines or sensors or whatever, but I'm struggling to isolate issues...
