Hydraulic Clutch in '69 CJ5
rocmoc
Tucson, AZ & Mexico (both Mainland & Baja)
1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
I am replacing the floor mount pedals with hanging pedals. '69 CJ5 with V6 & T-14 . Brakes are no problems. Clutch master cylinder mount is no problem. I need advice about how people mounted the slave cylinder and what master & slave cylinder was used? Did a search but found info only on newer inline 6 jeeps.
Thanks,
rocmoc n AZ/Mexico
You are always there tarry. Thanks
rocmoc n AZ/Mexico
$45.00
  22.5%
