Hydraulic Clutch - Strange Adjustment
- Media
- 186
- Resources
- 1
- Plumas Lake, CA, USA
- 1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
So, as most know, I threw a bunch of new parts at my jeep all at once
I installed a SM420, Centerforce Dual Friction Clutch Kit, adapter bell housing from Novak with clutch fork (modified for clearance) and the hydraulic clutch conversion kit from Novak.
I have a return spring installed inside the bell housing, on the clutch fork, and on the pedal (clutch pedal).
Here's my symptoms...
For the most part, around town it drives fine. Even on long trips. The pedal still seems to not fully return though (i'd say about an inch away from fully out) but engine and tranny do engage. I still pull the clutch pedal all the way out to avoid possible throw-out bearing riding.
When off road for a while, it seems to not "fully" engage the clutch when just releasing the pedal. Sometimes have to toe pull the pedal. not often though...
So questions:
I assume just adjusting the slave push rod like I would have if it was regular old clutch system. True?
My hydraulic fluid line is about 6"-8" away from my headers. They get pretty hot... If the fluid level gets too hot, what would happen?
I'm heading to the Rubicon again in a couple weeks, so want to try a few things out.
So questions:
