Hydraulic Clutch Woes
busterswt
Hello all,
I converted to a hydraulic clutch setup when swapping to a 350, and I'm having some issues with pedal return. Whenever the pedal is up all the way, and you push down to change gears, the pedal doesn't return all the way (about 1/2" short). Subsequent pedal pushes come up 1/2" short each time until you're right at the floor and eventually unable to engage the pressure plate properly. You can pull the pedal up with your foot and repeat the process.
Is this a symptom of air in the line? I have bled it many times and don't appear to get any air out of the system since the initial bleed. I'm think I'm overlooking something, but am not really familiar with a hydraulic clutch setup to know what's right/wrong. It's not behaving line air in a brake line would.
Any suggestions would be much appreciated.
Doing this soon, Want to see how it turns out.
