Hydroboost Install Pics
ThisGuyUKnow
Full Time Jeeper
Featured
Harleysville, PA
1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
I have some miles on this setup and just wanted to say that it is still working well. I had to chase down some leaks which turned out that one of the o rings didn't sit right. I wish I had did this first over going to a yj brake booster.
I did this swap again on my newest cj. I still used a yj booster bracket but this time I discovered that the stock CJ7 brake mc fit and worked just fine with the hydra boost.
I am working on this with my CJ, too. I already have the HB unit installed, I just don't have it plumbed except for the brake lines. Mine (I believe, anyway -- got it off eBay) is from a bread van. Not sure if the MC will be too big of a bore, but it seems to work decently without the HB lines hooked up.
My question is about the hose routing. I always thought that the lines were supposed to go from the pump to the HB in, HB out to PS box, then both return lines from the PS box and HB unit tee in together back to the reservoir? If I am understanding correctly, you have yours opposite of that. Not saying you are wrong, but I am just curious.
That is exactly how mine is plumbed.... I put an inline filter in the system though.
Out of curiosity, what did you do for the booster to the firewall bracket.
I can't believe I didn't hear of this sooner! I just finished my power steering up grade, and this is next. How do the brakes feel with the engine off? Like vac assist with the engine off or like a non assist MC? I have stalled it before, once.
The gold cylinder on the booster stores pressure for one or two brakes I'm stalled situations.
Yes with the engine off you have no assist.
If the hydra is working properly, you will get assist for one or maybe two brakes immediately after the engine is shut off. THat is what that gold cylinder is for, it holds a residual pressure, enough to brake if the engine is stalled.
You know, I don't really recall. I might just have to go look next time I'm in the garage. I may have oblonged a couple holes, but that's about it. It pretty much bolted right up. Odd thing was it seems that the pushrod was just the right length. But, I haven't driven it on the street with the booster hosed up, so I can't really attest to that just yet I suppose.
Nice thread, I should have removed more `80 Wagononeer parts!
Ok, so this is a Really old thread, but I'm about to do this and wonder how it has held up long term?
