I become intimate with a Jeep T-18
:p German cussing heh ausgeseitnet!
Wow, a ball bearing, I always used empty shell casings, a hole punch, scissors and blade.
Nice work.
I am going to post this in this thread and I will also be posting a subject specific thread.
The t-18a that I suspect is a 1975 jeep. One of the points of interest is that the assembly drawings indicate that I should have a "spacer ring" between the snap ring and the case where the input bearing enters the case. Mine, as you have it , is absent.
I have noticed that the input shaft has a bit more end play than I would expect which indicates the bearing retainer is not doing a sufficient job of restraining the bearing and/or the roller bearings between the input and the main shaft are incredibly worn.
The rabbit that the snap rind should be the thickness of the snap ring plus a couple thousandths, Mine is about .025 deeper than the snap ring is thick. this allows the bearing to rock.
If I cut a .02 shim to go behing the ring It will give me .05 clearance which should take a lot of play out of the shaft end. This also opens the 3-4 synchronizer up .025
The second possibility is to turn the face of the bearing retainer 025 and make the rabbit shallower. This also has an affect on 3-4 synchronizer.
And the bearings and the races at the input to main shaft point look good.
Now for the really important question, anybody have a trick and cool way of cutting shim stock into a ring whose ID is maybe a 1/4" smaller than the OD ??
I am considering .025 piano wire as well, 3 or four turns but it would be a problem keeping it in position.
I have found a web site that has a great way to cut the shim but it takes a day and a half to make the tooling. A lot of work for one shim, even if it is perfect. I don't see needing another in this life time.:D
Check your old setup for depth of the input shaft and bell housing.
I once put a T-14 replacing a T-150 (79CJ5) and found the T150 bell housing too shallow. Used the T14 bell housing and bingo.
Just something to consider.
I once put a T14 replacing a T150 (79CJ5) and found the T150 bell housing too shallow. Used the T14 bell housing and bingo.
the T-18 bell is setting on the floor . out of the picture. thanks for the look out.
Well done :chug:
