I need a little help
roadsidedoc
Samson, AL
stock CJ7 258, 4 speed,
modified CJ7 Chevy V8, th350, np208, 1 tons
I am finishing up our 350/1 ton project and need a little help with a few items.....I need a throttle cable and a throttle bracket for the chevy motor and the proper connection for the firewall and the pedal.....the parts houses these days are not much help
im running a 350 and using a stock throttle cable for the 2.5 iron duke engine. the bracket on the motor i got from a junk yard. are you running carb or inj.? im pretty sure the pedal side just snaps in the firewall in a square hole. same size hole that will be in the bracket on the motor
I got a generic mr gasket one from Summit. You cut it custom to the vehicle. I did have to use the AMC 304 bracket on my Ford. Had to drill a new hole but the square hole in those brackets should all be the same just find whatever you can.
