I need emotional help!
Reddrig
- Ca
- 1972 Jeep CJ5 304 T15 Dana 20 Holly Carb
Dana 44 rear
Dana 30 front 4.27 stock gears
Front and rear power disc brakes
35" Mickey Thompson tires with Mickey Thompson 17" wheels
Rhino lined tub with custom tool box
Rugged Ridge ORV 4" lift, 1.5 BL
So I've been fixing leaks since I acquired my rig. Did the inner seals on front axle which stopped that problem, tightened up the Transfer Case to tranny which seems to have cured small leak at rear of tranny. Did the rear main seal, new oil pan.
So I'm still left with what appears to be a small leak which looks like a rear main. I have a quarter size puddle after driving. I also changed the valve covers, no leak their. I actually re did the rear main again, and the same situation.
HERE'S MY QUESTION.
should I be content with this very small leak or should I continue to pull my hair out and problem solve a very minor leak? This is a 1972 Jeep after all. Would you older Jeep owners be content with this very small leak or would you continue to pull stuff apart? Give me your thoughts.
HERE'S MY QUESTION.
I had the same problem with a 360 awhile back but the leak was worse. A friend of mine told me to put a small dab of silicone on each one of the "feet" on the rear main seal. It solved my leak. If you haven't used that method I'd say it's worth a try. If you did I could live with a leak that size.
