Electrical Ignition cylinder.
Vikingone
Lake Worth FL
85' CJ7, 4.2 Liter, swapped in T18
So I installed a new ignition cylinder last week. While working on some electrical issues I found that the new cylinder would just pull out. Not too sure why. 84 CJ7
Did you install a replacement cylinder assembly or take it apart as shown in diagram from manual ?
The whole assembly is held into place by the torx screw.
The center plug will pull out of the body if it's not orientated correctly during re-assembly.
Taking the core or center plug out of the cylinder body is usually only what a locksmith would do.
Yeah I replaced the whole assembly. Don’t recall taking a torx screw out. But maybe I did. I must have because the old one didn’t pull right out. Now I have to try and locate a screw.
