Engine I'm about to throw the whole thing away...
mickey85
Valparaiso, IN
83 CJ7, 258, T5, Dana 300, Dana 30 front axle, AMC 20 rear, Trac-Lock LSD
Alright, I posted a few months ago about no spark with my 83 CJ7 (AMC 258 i6 / 4.2l , manual Transmission ) that's still running the computer, stock ignition, and stepper carb. Still, no spark.
Here's the original thread: https://jeep-cj.com/community/threads/no-spark.63786/
tl;dr: 1. Does the computer matter for ignition?
2. Is there a way to test the computer to see if it actually works?
3. Is it worth dropping $100 for a remanned computer, or should I just wash my hands of this damn thing and get a DUI dizzy and Weber carb? While I'd love to leave it stock, I'm leaning this way, just to clean out the engine bay of all the vacuum and wiring nonsense.
4. While I can get antique plates, I would like to run normal plates, meaning it needs to pass smog. Visual doesn't matter - it's just a sniffer test. Can I get the Weber to pass the sniff test?
To get a few things out of the way - yes, I have the factory service manual, as well as a Chilton's, and a CJ restoration guide. I have vacuum diagrams and wiring diagrams, both black and white and in color. I've gone through the entire troubleshooting list.
So far, when testing, I've found that the power wire to the red coil wire works (and when cranking, the light blinks when testing the red wire). The green wire shows a signal and blinks when cranking. When testing the module, I get power to the module. I test the resistance at the distributor plug, and it's testing at 620ish.
When Dad rebuilt the engine, he replaced the coil, distributor cap and rotor, plug wires, and coil. I found he bought a new module, so I installed that. Thinking perhaps that sitting for a decade killed stuff, I replaced the module and coil.
I realized that the negative terminal for the computer wasn't grounded, so I found a spare bolt on the engine block and grounded the computer (because I couldn't initially figure out which was the ground and which was the high-altitude, I grounded both to test).
I checked the ground, which I have running from the engine to the hold-down bolt for the fuel line on the engine mount (the frame side), and it's tight.
I just checked my spark plug test light tonight on my Harley, and discovered that that's dead, so that's fun. I still believe it to be sparkless, as it is definitely getting fuel and air.
cheap tester use a spare spark plug put the #1 plug wire on it then lay it on something metal and crank it over looking for spark. if the plug sparks u have power maybe just 180 out. if no spark check cap rotor etc
Sent from my E6810 using Tapatalk
Before running the diagnosis, I pulled the #1 plug and put it on the (metal) rocker cover. I didn't see a spark. Will use a screwdriver next to try to build a bigger spark.
if u didn't see a spark on the valve cover with a spark plug u probably don't have spark. pull the cap mark the rotor and crank the engine to see if the rotor spins. u may have a bad dis or dis gear
I'll check the next time I go over there. The only other thing I can think of is that the hot wire fell across the vacuum solenoid on the dizzy and welded a nice line across the top. Is it possible to cook the distributor where it's wired up to the ignition module?
i went threw the same
i had a 83 CJ5
the carb was shot
then the smog stuff was a hot mess to worked on it for weeks
the manual's parts replaced but finding parts was not a easy task
jeep supplement no.1
1982 jeep
technical
service manual
1983 Service information
it has all the test ports 1j-3 diagnostic plus to do what your ask
just remember theirs mcu and a ignition
after all the time and buy of manuals
mine was the carb that was just warn out and cause all sort of issues
could not find a new carb they did not make them
i end up buying a jfi injection system
it removed all the smog and the distributor
love the system
Alright, so if I go with an HEI distributor, does it matter which one? I've seen some stuff about getting the proper gear so that it doesn't grind down the cam gear. Is that a thing? Can I swap the gear off my stocker? Is there a cost effective (read:cheap) that would work ok? I really like the DUI, but I'm already into this thing for a whole lot of cash...
i prefer DUI as its a quality product. however the cheaper ones do work. most come with the right gear when you order it. swap meets typically have vendors that sell new distributors and have them. you will need new plug wires i believe the 80s ford f-AMC 150 with the I6 has the perfect plug wire length for a factory fit with no modifications and easy replacement from any parts store
AMC 258 i6 / 4.2l I 6's do not have this problem. 8 cyl's can.
Also, please fill out your profile with little more vehicle info. Hover over my others avatar to see what I mean. It helps us know exactly what you own.
258 I 6's do not have this problem. 8 cyl's can.
Thanks for the info! I updated my info (and threw up a pic of me and the jeep in question circa 1987). I'll take a look at the HEI's I can find online. I was leery to pull the trigger on a cheaper one, given the gear issue, but if that's not a problem on the I6, I won't worry about it.
I've been running this one in my AMC 258 i6 / 4.2l without any issues. Pretty cheap when you consider that it comes with plug wires. I have a Howell TBI on mine so I can't help with the carb issues, but from what I read that weber you mentioned is pretty easy to hook up...and you can ditch most of the vac lines etc. Assuming you don't have the smog nazis to deal with like I do in CA.
https://crtperformance.com/shop/ols/products/amcjeep-232258-42l-i6
ive used that b4 on budget off road rigs without issue myself. as for carb i do prefer the MC 2100 over the Webber. much more forgiving for the novice carb tuner and easier setup
Thanks guys! I do live with smog Nazis, so I figured that as close to stock as possible would be a good idea. I bought the CRT dizzy, and also a remanned Carter 2bbl that's pre-smog. That way I can keep the air cleaner and the pulse air system (it's a Cali spec model) and not have to mess with sealing off the exhaust downpipe or cat take offs.
I'm not subject to a visual (I don't think), just a sniffer, so hopefully this works okay. Also, $95 for a carb was a hell of a lot easier on the wallet than $300+for a Weber, air filter, etc.
I grew up tuning quadrajets - hopefully a really basic 2bbl isn't going to be too difficult, though I'll admit it's been 15 years since I've messed with carbs in anything other than motorcycles.
I'm going to work on it today and add some dedicated grounds on it. Hopefully that solves some of the other issues I've been having.
keep us posted
It's alive! Of course, I already ordered the non BBD carb, and the HEI, but I decided yesterday to go mess around with the jeep, and install some dedicated grounds. I grounded the alternator, the distributor negative wire (on the harness side) and the negative battery terminal (on the dedicated ground, as well as of course the main cable). Cranked it and got spark! It must have been a bad ground.
So, I'll run it with the original setup until it decided to die, then we'll see about swapping new parts to it.
Awesome!
Speaking as someone who has a DUI HEI - I'd keep and mod the stock set up if I had it to do over again. My DUI ran in my AMC 304 , and swapped to my new built 360 just fine, however I suspect it's not phased / tuned right for what I want, and I've been too lazy to do anything about it. Get's a bit technical without computers... Then again, I don't know a lot about your year / engine.
Point is, it (the DUI) runs fine, and does what it needs to, but I can't help but think it's holding me back on tachout situations, however so is my MC2100 2 barrel unless i overjet, so... lol And don't get me started on the damn 4 barrel aluminum intake fiasco of 2019! I digress...
To answer your question on the gear thing - just make sure no matter what you're working on you don't have a hardened gear and non hardened gear playing together. As CJ said, I had it happen in my 8 cyl, from what I've heard 6's are ok normally. Best advice, change the stock gear to new distributors, they already play together, so keep them together. If they're worn, retire them both and get a newly wed couple (matching set).
Glad you got her figured out. They're a pain in the ___ sometimes right? So are boats... :rofl:
    Best for votes
    on specific items
$35.00
  17.5%
