Individual throttle bodies
craveman85
Dolgeville ny
1981 cj8, gm 151, sr4, Dana 300, Dana 30, amc 20, 3.73s
Anyone on here ever make an individual throttle body efi setup for the AMC 258 i6 / 4.2l or 4.0? Any recommendations on what ecu to use and what else I'd need? I was thinking that an intake could be made from cutting the gasket shape out of a piece of aluminum plate then welding runners off that for 6 throttle bodies. Maybe with one long oval shaped air cleaner. I suppose I could go with carbs but would like to check both my options.
A common throttle body for an efi setup would be the Rochester 220. Used with the GM p/n 1227747 ecm along with a lot of sensors. Howell Engine Developments does make an adapter for the AMC 258 i6 / 4.2l , not sure about adapting to the GM 151 . I have heard of guys machining their own out of a block of aluminum. Howell does do custom applications, you could check with them.
wow thats a lot of work. I think the individual throttle bodies on each cylinder is meant for wide open throttle applications. A Jeep spends most of its life near idle and needing torque not horsepower. I also recommend you check out Howell efi they make a great bolt in efi system using the old GM throttle body system which is what I want to go to on my Jeep. If you should decide to go with multiple throttle bodies do share it would be interesting to see.
