Inherited CJ7
- Media
- 186
- Resources
- 1
- Plumas Lake, CA, USA
- 1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
Take the body off and blast it now to clean off all the surface rust you can. Then use few rattle cans of primer (rustolium or whatever) and put a good coat over it and store it. You can always blast it again later to fix like the finder ding the power steering pump made in the internal fender I assume during the tow to you etc. This way you get rid of and stop further rusting while you sort out the rest.
From there, if it were me and I had put years timeline on this, I'd strip it down to bare frame taking photos at every step of how things are / look.
And start back from the frame with 1 project at a time pretty much. Get the frame all fixed up, painted or replaced. Then start with suspension and any changes or upgrades / rebuilds on the front and rear diffs.
Then engine and tranny / transfer cases etc etc.
Some steps may require you to know what your end game is first, so planning the whole build out helps, but be prepared that things change. What if you pull the cover off the rear end and the ring and pinion and spiders are rusted to heck and back or broken. You may have to rebuild is, which means you'll be 50% of the way there for a re-gearing job that may really improve your end game.
There are some really good build threads here too that may help you see the processes others took and what they ran into along the way.
One of my favorites was Bill's:
https://www.jeep-cj.com/forums/f98/bills-75-cj5-ground-up-rebuild-9190/
From start to finish total ground up rebuild... little different year wise and 5 not a 7, but it's a good build and guideline all the same...
And as always, we'll all be here for a question or opinion
