Installing a locker
Oldguyinajeep
- Media
- 9
- Derby, KS
- '86 CJ-7 258ci 4spd Dana 30 and 44
Howell TBI Fuel inj, Headers, Dual batteries, Warn winch/air compressor, rear
disc brake conversion, Detroit locker (rear), Eaton E-locker (front), 4:10 gears, 2.5 in Rancho lift, 1" body lift, fully armored, 35" BFG KM2s, Warn front hub conversions, line locks front and rear, roll cage, warn front bumper, rock hard rear bumper/tire carrier, DUI ignition, dual electric fans, LED rock lights
I am in the process of choosing a selectable locker for my Dana 30 , on the front of my CJ7 . Will go with either an Ox or an Eaton Elocker. My understanding is that the carrier is the same size, so my pinion depth should be the same when I remove the ring gear from the existing unit, and replace it on the new locker. I should then only need to shim for proper backlash. Is this accurate?
Although I've done lots of wrenching on my jeep, I have no experience with setting up gears, and I'm a little reluctant. If it's only the backlash to adjust, I'd feel pretty confident. Otherwise, I'd probably let a mechanic do it.
Any input is appreciated.
