Intake/ head question
1970 beepbeep
Iowa
82 CJ7, 258 motor, 4 speed.
Couple of questions. Friend has an 80 CJ7 and has a AMC 258 i6 / 4.2l block with newer F.I.head (4.0?) Wants to return back to stock and go with carburator.
1. Can he use newer style head with the F.I. intake and remove the throttle body and swap on a Weber?
2. If he cant use the newer F.I. intake to adapt a carb., can he use an period correct intake and bolt it to the newer head? Wondering if the intake ports are different.
Thanks in advance, Rick
:agree: just find an 80 something aluminum manifold to replace the FI manifold.:cool:
This is interesting, I don't see why the Weber, if you can find an adapter, won't work on the 4.0 intake manifold? I have a tbi mounted on a carb manifold and am satisfied with the results.
Thanks brothers! My friend and I thank you both! He still likes carbs, thats why the swap,plus I have a fresh weber to donate to his project. So he will gain some performance with the newer head? I thought maybe the ports wouldn't match up ,hence the question Can he use a AMC 258 i6 / 4.2l valve cover?( wants to dress it up) thanks again!
Rick
I don't think the cover will work but 4.0s came stock with cast aluminim covers.:cool:
Well its a common thing for carb to tbi swaps. Its not a common thing for swaps from chrysler mpfi to any type of carb I don't think anybody makes an adapter for that. Although I suppose it could be done if you had the right tools to machine an adapter. You'd probably run into several other problems too. Not worth the investment most likely
Sent from my DROID3 using Tapatalk 2
IO - bought the bung and had it welded on, used a couple of tubes from an early 4.0 (pre H.O. IIRC) did a cut and paste, well the shop did it. It is pictured in the link to mounting the AMC 258 i6 / 4.2l intake to a 4.0 head in the above post.
I did the reverse on the marking.
Using the studs made things a lot easier for mounting. The studs that I have used an allen key in the end to tighten them with. No double nutting to install.:D
The squares ended up more big rounded triangle shaped after grinding them to fit the space.
