Intermittent Sputtering/Stalling
Too old to Care
- Seattle, WA
- 1985 CJ7 Renegade, 258 C.I., Howell EFI, NV3550, Hydraulic Clutch, 2.5" lift, Warn XD8000i.
This one is driving me crazy; I need ideas:
1985 CJ7 , AMC 258 i6 / 4.2l , Howell EFI, stock distributer. Daily driver. Remanufactured engine was installed in 2004 and Howell EFI conversion at the same time. I do all my own work and the CJ ran flawlessly for 8 years from day one until a few months ago.
Symptoms: After a few miles the engine will start to sputter and try to die. I have to pull over and pump the throttle vigorously for 4-8 minutes to keep it from dying. Then it will suddenly run fine, but will do it again within a mile or two. I cannot determine a common situation or factor; sometimes I can drive it a week without incident, sometimes only a few days, sometimes it does it every day. Sometimes I get an ALDL code 44 & 45, sometimes no error codes at all. Always starts fine when not driven for a few hours.
Actions to date: Changed rotor & cap; checked hoses and wires for breaks, shorts & loose connections; replaced fuel pump & filter; replaced fuel regulator in throttle body; replaced fuel injectors; replaced fuel pump relay; new hard fuel line from pump to TB; replaced ignition control module.
What have I missed??? If the ECM is bad it should kick out an ALDL code shouldn't it? Do I need to drop the fuel tank and look there?
I know a lot, but I don't know everything. Any of you motorheads run across this before? Thanks.
can collect in a tank after 25+ years. I would like to know how you got a NV3550 in that CJ.
