Electrical Intermittent wiper module/switch...
Project86
Old Time Jeeper
Tx Gulf Coast
1986 CJ 7 Blue
2004 Chevy LWB CC,
2012 Corvette Grand Sport
1986 CJ 7 Red Garnet
1978 CJ 7 Kinda Orangish
Never used one but I know what it is. It's basically an adjustable time on / time off relay. CJ's have both a high and low speed feed and the motor parks itself.
The 4-wire wiper motor for CJs has the ability to do intermittent if you have the switch and control box. The 3-wire motor can work, but you'll lose the "park" feature. If you don't have the switch and delay module, then the unit you pictured will retrofit to provide intermittent functionality. That module uses a common 555 timer chip and a basic RC circuit (using the rheostat as the variable resistor in that circuit) to change the charge timing on capacitor C2 to trigger the relay. Not going to be room in the original dash location to mount that switch with that circuit board hanging behind it. Plus you'll lose the washer function of the stock CJ wiper switch (push to wash). Might be better to simply get the right switch (Crown #J5758904 or Standard Motor #DS-577) and the delay module (#SF3728007). The delay modules are getting harder to find, but still available of you look. Here's one on eBay: Delay module on eBay
And here's the whole setup, with the delay module, the switch, and even the chrome bezel: Intermittent wiper parts on eBay
Mid-80's Ford switch and delay box should also work as they used the same connector plugs.
I would be interested to here if that works, no one reproduces the factory delay nor makes the switch plugs
Wife is out of town this weekend, so I'm gonna wade into the shallow end of the pool and see what happens. Thanks, for the replies and options.
$190.00
  95.0%
