Iron Duke Problems / Tuning
truk820
Chicago
1981 CJ7, Iron Duke 151, SR4 transmission
The clicking sound is probably the starter relay, this could be from a weak connection,weak battery or worn out starter relay. The relay can be checked by bypassing it, as I recall that would be by running a jumper between the "S" and "I" terminals, I use one of those push button attachments to check that. Your running problem sounds like a fuel related issue, like maybe poor fuel pump pressure or low float bowl. Or is it runnung too rich?
It doesn't seem to be running rich, I guess I'll read up on how to tune the carb though. Fingers crossed it isn't too difficult.
Re: the starter relay, how tough is it to replace? I did a quick search on Autozone and it doesn't look too expensive.
Replacing a starter relay is a simple parts swap if that is your problem. The more important part is making sure the electrical connections are good. Your float bowl level could be the issue, did you install a new fuel pump?
Nope, never installed a new fuel pump. I'd ruled that out because once it fired up it'd run continually although the problem of me having to continually feed it gas may indicate my fuel pressure could be off. Is that a common problem?
You should know if you are even getting enough gas to the pump, as old as the vehicle is anything could be wrong with it. I would begin with making sure there is enough fuel in the float bowl and is the float bowl level set correctly. Then make sure the fuel pump is working correctly, This is best done with a fuel pressure gauge.
unfortunately without being there it is hard to tell for sure but you need to get the basics down, check/set correct ignition timing, check float installed height, set carb idle screws, check/clean trash in carb/ fuel lines/ tank check for vacuum leaks :D
Yeah...this is what I was afraid of.
Of everything you've listed, how would you order it on the level-of difficulty scale, from easiest/cheapest to toughest/most expensive?
