Is my fuel pump going bad?
venom
After having to mothball my project for the holidays, I went out to start it, just to keep the fluids moving. When I cranked it over, I found that the pump wasn't picking up fuel. It wasn't like I only cranked it for a second or two, but quite a few seconds. I ended up putting fuel into the carb to get it to kick over, and at that point it seemed to pick up fuel and run as expected.
Is that indicative of a fuel pump going bad?
Now, to add to the mystery, I have an in-line fuel filter in place. I put it in years ago for some long forgotten reason, but I have noticed that the fuel will drain back to the tank. I'm not sure if that's common and expected or not.
After the new year I'll be picking back up where I've left off, and if I should replace the pump, I'll get it done. I there's something else I should be looking at, please point me in the right direction. I can say that the fuel lines all look good and there are no apparent leaks, so I don't think that's the cause.
Thanks, guys!
Thanks, guys!
