JB Twin stick install T-150/Dana20 77CJ-7
Dan77CJ7
Denver,303Local
76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
I just installed the JB fab twin stick conversion. DONT CUT shift pivot bolt i didnt need to but i also didnt remove interlock pills so if you do you might need to cut. it was striaght forward follow directions went smooth. i didnt lower Transfer Case i drilled a hole to get to the shift support bolt that holds the shifter levers then dry fit all the part and had to bend the lower brackets on the front drive stick a coulpe times untell i got smooth motion. i put it togather and took it apart about 10 times to get bends right. if you have any questions i can do my best to help. this kit is the best shifter out there Stock or any other after market Twin stick so beware...... JB is the the real deal!!!!! Thanks.
Heres the finished product. and i added a new Grant 414 steering wheel, to be honest the steering wheel was harder to install than the Twin stick. If you get this wheel be very careful when you remove the center plastic ring to get the horn button out, its really brittle! and if you already have a custom wheel you might not need the install kit, i didn't and saved $26. good luck and run'um hard!
