Jeep Girl hopes to upgrade 1976 cj7 jeep to gm tbi...Please Advise..
76cj7chick
Old Time Jeeper
WA
1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
I'd try someone like Howell or ebay for the adapter.
The GM Turbo 400 is pre computer so you don't need anything there.
Here's a good read on the wires.
Wiring - Binder Bench
There is a lot of info out there on the junk yard t.b.i. system, I assume where you are from a smog inspection is not required. I have learned quite a bit on these setups just by working from a kit that I purchased, and still continue to pick things up as I work with that system. Good luck with your what you decide to do.
Thanks for your quick replies... :chug:
I checked out the adapter plate through affordable fuel injection and its a whopping $175! :confused:
I also checked out Howell's adapter plate and it costs $95... That is if Its the correct one. (ADAPTER PLATE: Holley 500 2-bbl to GM TBI, .5" thick CODE: H2J)
Howell, or Affordable would definitely be the easiest route for me... But not the cheapest...
If anyone has a kit they don't need anymore please let me know how much for the kit.
The main two things keeping me from going "junkyard"... Is getting/making the correct adapter plate and making sure I get the correct prom for the ecm.. That is If one is needed..
I'll keep researching about the junkyard swap.. In the meantime, if anyone has any additional helpful information PLEASE share with me...
:notworthy:
I never had a jeep 400 turbo but if that is what you have then it may not have the same bolt pattern as a chevy..I'm pretty sure that it would not
The TH400 is pre computer so you don't need anything there.
Hi Olddog,
Thanks for the information on the tranny... And the great detailed wiring information.
Now I just need to find pictures for how the tbi system is supposed to look on a 76 CJ7 (now with a 2 bbl intake)... :chug:
:confused:
I have the AMC 258 i6 / 4.2l AMC 258 i6 / 4.2l engine and GM Turbo 400 Transmission and the Dana 20 Transfer Case out of a full sized jeep truck.. A previous owner did the swap.
Since my cj is a 76 it only came with a 1 bbl intake that was "married" to the exhaust manifold. I installed a 2 bbl intake manifold and separate exhaust manifold. Thankfully the exhaust manifold has a o2 sensor port. :D
So, the conversion shouldn't be a problem... :rolleyes:
:o
sorry..for some reason I had chevy on the brain
First...Unless you use a Holley adapter plate too, that Howell adapter plate won't work. I tried that on mine and could never get it to seal and had vacuum leaks. I ending up making mine. $7.00 worth of scrap 1/2" aluminum plate, a drill press, taps and hand file. Took about an hour.
Second...Don't get to hung up on the Prom. The AMC 258 i6 / 4.2l and 4.3 are so close in size, factory fuel tables work real well unless you run amodified cam, high compression and headers. I haven't touched/reprogrammed mine. "Don't fix something that's working" Best advise I can give you about that is just make sure it comes out of a vehicle with an automatic and stay away from any with a 3 digit BCC which would be in 1987 vehicles. I'm actually using a 16144288 ECM BCC AUMH out of a 1990 G20 van
Second...Don't get to hung up on the Prom. The 4.2 and 4.3 are so close in size, factory fuel tables work real well unless you run amodified cam, high compression and headers. I haven't touched/reprogrammed mine. "Don't fix something that's working" Best advise I can give you about that is just make sure it comes out of a vehicle with an automatic and stay away from any with a 3 digit BCC which would be in 1987 vehicles. I'm actually using a 16144288 ECM BCC AUMH out of a 1990 G20 van
So it looks like the biggest challenge for me is to make or find a decent adapter plate that doesn't break the bank.. :o
Thanks for the information about the prom and that I should get the ecm from an automatic... For a while I was really worried about not getting the correct one for my CJ7 . ;)
I've priced parts at my local junkyard and some of the prices are the same as new parts.. :eek: (ex. o2 sensor and fuel filter to name a couple)...
What is the difference between the 16144288 ecm and the 1227747, if anything? :confused:
Would aluminum or steel be best for the adapter plate? Any ideas where I can find a good scrap piece? I may check out the bin at our local recycle center... :rolleyes: I may be able to cut my own adapter.. I have some tools... :D
Thanks for your help! :chug:
Oh by the way could you give me the measurements of the adapter plate? Also, do you think 1/2" thick is the best or thicker? :cool:
I would like to hear about how much fun you have when you put it together. It is quite an educational experience. One comment about the Howell system, They seem to be underwired, as they saved money by installing as small of a gauge of wire as they could get away with. From what I hear the Howell guy was the one who designed the fuel injections for GM.
