Jeep starting issues
LaradoMTNrunner
- Greeley,colorado
- 85 cj 7- 258 l 6,t176 tranny 4speed,stock front and rear diff,
Here is what happened pulled a dumba@@ move put battery on backwards when hooked up puff of smoke in hooked and cleared out garage to access the problem! Backfeed into starter silonid only melted one wire partly to the altnator. Replaced the wire bought new starter silonid. It will start but as soon as you let off of the key it dies won't stay running? Has prior wire hacking and no brain box! Things that I have done to fix said issue:
Another new starter silonid
ICM old one was oem
pick up coil
Ignition switch
Reset key tumbler gears
Light tested ign wire from sinolid to ign switch
Spark plug test coil to dist to spark plugs
Not sure what else to do ???
ICM old one was oem
pick up coil
Ignition switch
I'd pull, not paying attention to what I'm doing.
