Trans Jeep t18
Trans Jeep t18
Tech1129
Tacoma wa
78 cj7 amc 258 t18 Dana 20 Dana 30 amc 20 4.10 gears currently frame up rebuild
T-18 question I have a jeep t18 with the 1” spacer plate and bell housing will this fit as is in my CJ7 ? I keep reading I need a short input shaft and different bell housing but I am getting confused as if it will fit as is
Are you sure it's a Jeep CJ T-18 ? They are pretty hard to find. Sounds like you have a Ford t18 that has been modified for CJ use. Can you post some pictures?
Here some from my V8 swap.
The shaft length is gonna be the issue. Looks like it may have come out of a FSJ...those had varying input shaft lengths with varying adapters and bell housing depths to match.
Plenty of options to mate one with a GM motor...far fewer for the CJ platform
Novak at one time offered a shortened shaft and retainer for the 6.32...not sure there's an option for the 4.02
It’s a 6.3 ish granny pooped the top and counted the drive teeth so I can get a new shaft. Just trying to fit see if I can get away from changing stuff around
$20.00
  10.0%
