Knocking at top end when warms up get louder-noise speeds up with rpm
CJB4POWERBILL
- Shelby,NC
- 1983 CJ7 258 4.2 I6 - T5/300 - Dana 30 Front - AMC 20 Rear - motorcraft 2100 carb, nuttered factory dist, all smog emisions removed, Bridgestone Desert Dualer 31-10.50-15 tires, Upgraded Heater Blower to the Blazer 103, Sunpro RPM gauge, Sunpro mechanical oil gauge, new main bearings, main rod bearings, oil pump, RMS, distributor gasket, oil pan gasket,
i did replace main rod bearings in journals
I had up in there( And I had just changed oil 3 weeks ago when I replaced lower end bearings). Everything is good for right now engine wise on my new jeep project FINALLY
