Knocking Sound When Turning Hard
- Featured
- 2
- Media
- 9
- Solutions
- 3
- Pittsboro, NC
- 1981 CJ5/258 4.2L I6, Tremec T-176 4-speed, Dana 300, Power Steering, Howell Throttle Body Injection System, Warn Locking Hubs, Warn Rock Crawler front/rear bumper with Tire Swing Carrier, Full Roll Cage, Pro Comp ES9000 shocks
Hey Guys,
So I recently had to parallel park my jeep and i immediately noticed loud knocking sounds from the front end every time I turned hard left and right. I've got power steering, 4 inch lift, and 31's. This was the first time I experienced so much noise when turning. I thought maybe I broke a tie rod or ball joint, but it drove fine afterwards.
I was definitely turning harder then normally to get into that spot. I normally get a knock every once in a while when turning, but it doesn't happen a lot and not that loud. I just replaced the tie rod ends, and I hope I don't have to do the ball joints as well.
Any Thoughts?
Any Thoughts?
You sure you weren't hitting the other parked cars?
Just thought you might need some cheering up.
