Steering Lares powersteering pump & OEM bracket
DconZ
I picked up a new Chrome Lares powersteering pump from Summit but when I took it out of the box yesterday to start prepping the brackets etc.. I noticed the return line inlet isnt going to work with the OEM bracket. They placed the low pressure inlet to the bottom corner whereas a factory fit pump is more in the middle which lets it pass through the opening in the bracket as its meant to. I looked at the possibility of modifying the bracket by cutting the hole a bit bigger but its too close to the edge and will weaken the bracket too much is my guess This pump is listed as a direct fit on a CJ which its not obviously (might fit a AMC 258 i6 / 4.2l mount) but they also list a ton of other AMC vehicles, wondering if AMC made a bracket for a matador, hornet, amx or something that has a bracket that has a different configuration that might work, been looking around but havent found anything yet.
Anyone been down this road?? I will likely end up returning it and picking up a Borgeson or something but this chrome finish is really nice and they seem to be the only one that sells this pump in Chrome
