Lift Kit
HackFabrication
Old Time Jeeper
- Canton, MI
- 1976 CJ5,
2020 Grand Cherokee Summit,
2018 GMC Sierra 1500 SLE Regular Cab Shortbed
JMHO, but I'd take it to an alignment shop and have them check it. They've got the fancy equipment that will give you a printout of what your numbers are for both sides.In the article I read, it said to set the caster to a positive 4 degrees because this is what most jeep were set to. Sound about right?
5-7 degrees positive is a good place to be. A little more won't hurt if you want to go 6-8 degrees. Negative or zero caster is not good. Before I added 6 degree shims, mine was at '0' on one side, and -.5 on the other. 2.5" lift, it liked to wander all over. Now it's arrow straight at speeds up to 65 mph (haven't ventured above that yet).
