Lifted CJ5 questions
Total Chaos
- Panhandle of Florida
- 79' CJ5, 304, stock T-150 3 speed, 20 transfer, Dana 30 front, AMC rear
I am new to the forum. It has alot of good reading material.
I have found a few threads here that have somewhat answered my questions, but I want to make sure I am on the right track.
I have posted some pics of my Cj, 1 after I got it, during the rebuild stage and the rest after I finished (never finished).
Here are my questions:
1. After doing some measuring to determine the current lift(as described very well in one of the threads,). It appears to be to be 2.5". Does it look right?
2. It also looks like a body lift as well or is this stock? I measured the spacers between the body and the frame and came up w/ .75". There are noticable gaps from the splash pans in the fender wells to the frame.
3. The original tires(when I bought it) were Q78 Buckshots on 16" rims (see pic during paint work). The rubber cleats on the sides rubbed the front springs on a hard turn, which ruined the springs(loose & shifted). Since then I replaced w/ 15" deep dish on an economical set of 33x12.5 A/T's. I want to move to ProComp Xterains 35x12.5's, after replacing the lift w/ the same height. Do you think I'll have the same problem? Any other potential rubbing problems?
Thanks for any input.
