Locking rear axle
Bill D
- Media
- 16
- COLORADO SPRINGS, COLORADO
- 1980 CJ5 Renegade. 6-258 engine, Howell FI, T-176 four speed, 300 transfer with Terra Low 4:1 gears, Dana 30 front with ARB air locker, AMC 20 rear with one piece axles and welded axle tubes and an ARB air locker. Both differentials running 3.73:1 R&P's. Onboard air, Warn 8,000lb. Winch- - -
2003 Jeep TJ "Rubicon" with all the Rubicon goodies, Terra-Flex 3" lift, adjustable track bar, sway bar disconnects, LED headlight conversion, Quadratec 9000 winch. - - -
1963 Willys CJ5 with a 134 ci F - head, three speed T90 tranny and a Warn overdrive. - - -
1949 CJ-3A. My latest acquisition and favorite plaything.
First, I'm pretty much a "newby" when it comes to Jeep mods. In the past it was always "buy it and drive it" but my last aquisition came with a couple of items that just may not be optimum for the type of off-roading that I want to do. The Jeep in question is a 1980 CJ5 Renagade with a AMC 258 i6 / 4.2l six, 176 Transmission , 300 transfer, and an AMC20 rear axle with factory installed trac-lock. The tag on the differential cover says that my axle ratio is 3.07:1. I'm also running BFG All Terrain 32" tires. I know that the 3.07 isn't the best ratio for anything even remotely associated with rock crawling. I think I probably know the answer to this problem (changing out both front and rear ring gears and pinions to something closer to 4.11:1) or having lower gears (Tera-Flex) installed in the Transfer Case . The former probably has advantages over the latter so I'll probably go that route at some point in time. The problem that I would very much appreciate help with is the "trac-lok in the rear. Right now, in low range four wheel drive, the trac-lok seems to bind and build up pressure until it lets loose with a bang. I've been told that the cure for this condition is probably an overhaul of the differential but I would rather go to a locker. Problem is, this whole thing is running into serious cash in a hurry. ARB makes nice lockers but they go for about $1,AMC 150 plus install and an additional $275 for an air compressor. OX makes a locker for about $850 plus install but again a shifting method puts another $150 + on the bill. Also, I can't seem to find an OX that works with the 3.07 gears. Detroit Lockers were suggested but my conversations with folks that have used them suggest that they have some characteristics that I probably don't want to deal with.
I know this is getting wordy but I want to describe my conditions accurately. Anybody got any good advice for me?
). Posi rode with me and a friend of mine in 2014 and I was never needing more power or more gear with three of us in there. I presently have two-piece axles torqued down tight, and I've welded my tubes but have no trusses.
