looking for an alternator upgrade
frhrwa
- Media
- 6
- 1984 CJ-7 (just bought it, so I have to do some work and see what it has in it.. other than 4.2L Auto.. 4" lift, 33" tires... my '75 had a 304 2" Burbank supspension, warn winch, full cage, all the goodies, the '79 had a 401 turbo charged hi-po with t98 or 18, which ever one had the granny low first gear (never can remember which).. had all the items needed to 4wheel, none of the show and go poopie.. I don't believe "chrome will get you home"! I'm also not one to go out to see if I can tear up my jeep, I go where I must, usually with a group that I hung with.. Used to be part owner in Diablo Off Road Center in Concord California.. Jack Essex owned Diablo 4WD, George Clause was Mr. Base CAmp, and mine was "Sounds Etc" all under one big roof "the Diablo Off Road Center"..
like the upgrade for the blower motor on the heater, there must be a part number that upgrades the alternator.. just added a winch, lights, etc.. have the stock alternator that doesn't get over 11 vdc when anything like the heater, turn signals, etc are on.. but.... my alternator uses the serpentine belt, so.. what alternator in the 135@ and up will bolt up? if anyone has done this.. I had a/c, disconnected it all, but the compressor is still mounted since I can't find a bracket to add an idler pulley in place of it.. will add second battery also, with rectifier (isolation) circuit.. the alternator as it stands is on the passenger side, under the a/c compressor, turns clockwise.. AMC 258 i6 / 4.2l 4.2L '84 CJ7 by the way.. NO EMMISSION
, so that stuff is gone.. guess since I can't find the by-pass pulley, I'll just do that onboard air system..
