Loose hub bolts
Loose hub bolts
I like it, I'm gona do the same IO. You could use them either with the stud method or standard bolts, the only down side I see is not real conveneint to check for tightness but in theory at least you should not have to.:chug:
I have also had the loose bolt problem, but if you take them apart and grease them regularly they should not get loose, i check mine once a month so they really never have the chance to loosen
I found, upon inspection a few months ago, I was missing one bolt on one hub...
Thought some du-face had forgotten a bolt on re-assembly one day. Now i know what actually happened.
Need to go home and check them all out... was waiting until rebuild the front diff to pack bearings and replace missing bolt, but might bump that up a little :cool:
Thanks all for the useful info / thread!
~ JR
I don't understand these "internal style hubs"
Somebody school me.
Ohhh.
Splines in the hub. Splines on the shaft.
The bolts don't keep the hub from rotating. The splines do.
Yes, I can see why that's a better design.
73CJ
Can you help me find the particulars in the ford internal swap you're mentioning. I'd like to explore the option further.
~ JR
dont keep this a secret. please let us all in on your hub secret. no one likes carnage like the earlier pics. please dont let it happen to anyone else
lol.
If he doesn't post it I will if you're interested.
So far we were both busy over the weekend, so minimal info was shared.
He's going to be trying to get some pics and such together, but mainly seeing if it is compatible with the Dana 30 front, as his is a Dana 44 waggy shortened.
I'm, so far, still leaning towards the fixing what I have option, but when I am ready for disc's up front and possibly a D44 option, this would be sweet info to bookmark :D
~ JR
I can not believe none of you guys use safety wire!!!!!! or lock wire as some may call it, I come from a off road race background and this is commonplace on a race vehicle, anything that does not use a nut, gets wired, its very simple, small hole in the head of the bolt and .020 stainless wire gets threaded through twisted tightly and then routed through the next bolt, it has to be done it the right direction to avoid the wire pulling it loose rather then tight, but once you get the hang of it, it is very easy, I drilled my bolts out myself with a drill press but bolts with holes can be purchased and a good hardware store or race shop, much cheaper then all the other options and it works perfect! mine stay tight cause the wire will not let them come loose, its a perfect fix. if any of you guys need a pic to help explain, pm me a I can text you one. I cant seem to get one on here...
I'm "semi-new" and this is only the second time I have heard of this option... Would you please post some pics?
Here's a link for how to post pics, if that's what you meant about not being able to post pics here... http://www.jeep-cj.com/forums/f16/how-attach-images-post-1270/
~ JR
unfortunately my problem posting pictures is that I cant get them on here from my phone, ill use my camera, that connects to my pc and I can load them that way. I will do it tomorrow cause my garage is dark now and they will be hard to see. check back tomorrow evening :D
No worries bud, whenever you can.
If easier for you, I can PM you my phone number and you can send them to me, then ill e-mail them to myself and post them up for all, either way though no hurry!
Cheers and thanks! :chug:
~ JR
OK Let's talk about the spindles
  • 3 spindles in the picture are D30, D44 Waggy (78) & a Chevy small bearing spindle
  • All have a 6 hole 4" bolt circle
  • All have a 3.375" pilot stub that mates to the knuckle
  • I used the Chevy small spindle with A10 wheel bearing sets
  • And the 1978 Waggy D44
Hubs/ rotors
  • F150 early 90s
  • Internal Warn hubs
Caliper & mounts
  • 78 Waggy
I'll go check the axle shaft sizes
I think I am over my head with this... I get "it" mostly...
But not sure... 73CJ you should do (or maybe you already have) a how to thread / write up! :cool: I'll sticky it for you and make you famous for life! :laugh:
~ JR
