MC2100 Alternative
mriplaybass
Full Time Jeeper
Since I have recently retired, I have decided to clean out (excavate??) the mess in our shop so that we can start in on our project vehicles, and enjoy life. The 79 CJ7 has been waiting patiently in the barn to have some upgrades done, and there is now enough room to put it back in the shop and let the fun begin!
"Chip" as we have named the most recent Jeep acquisition, since this is the 4th CJ we have acquired. (From the potato "chip" commercial: "Bet you can't eat just one", we can't keep from buying just one more.) Ran fine since we built it last spring. It has been parked in the barn most of the winter. When I went to start it up last week, I could not get even so much as a pop. Poured a little gas down the carb throat since, as I have posted before, the carb runs dry after a week or so, nothing. Gave it a little sniff of starting fluid, still nothing. Now the battery is getting low, so I put it on the charger over night. Next day, I checked for spark and had a good arc. More starting fluid, crank, crank, crank, still not so much as a bang through the intake.
Maybe it didn't help that it was below zero, because the next day, when it was around +20° with a little starting fluid, we had ignition, and lift off!
Drove it into the shop and began trying to decipher why we are having so many starting problems. It did not take long to find the problem. Two of the four bolt lobes on the carb were broken!
I don't know how this happened just sitting in the barn. Temperature swings? I have no idea how something which was properly torqued, broke so long after being torqued. It appears that the insulator/spacer under the carb deteriorated and crushed over time.
Now that I have vented, I will get to the real question (finally!) I will probably replace the carb either with another MC2100 or 2150 along with a new spacer (aluminum, OEM?). I'm pretty sure I remember the old one being a 1.08. Has anyone used either of these carbs from a Ford engine? How did it fit up? Is the bolt pattern the same as the Jeep version? And, what other carbs would be a direct fit to the stock AMC 304 manifold? Holley, Carter, etc.?
