Mechanical and electrical fuel pump question
mopar440cu
- Sumterville,Florida
- !979 CJ5 Silver Anniversary model with AMC 360/340HP, T18a, Twin stick Dana 20, AMC 20, D30 (both rebuilt w/ 4:56 gears) Moser rear axles with trac loc and 36 TSL Swampers.
I have a 1979 CJ5 AMC 304 with a mechanical fuel pump and my fuel pressure reading is really erratic and low. The reading goes between 2-3 @ idle speed. The pump was purchased last year, but it would not surprise me if it went bad. So, since it was giving me fits trying to start and low pressure, I decided to place a in-line electrical fuel pump close to the fuel tank and run it from a switch on my dash. Well after all was hooked up, filter changed, I let the pump run for a few seconds, shut the pump off, then attempted to start it. It still took too long starting it, plus the reading never changed 2-3 @idle. My next step was to keep it running and switch on the electric fuel pump and see how she ran and what the gauge said. Well, too me surprise, the engine RPM raised up a little and the reading was right around 5-5.5. Weird??
My question to yall is can I run both the mechanical and electrical together or should I do just one? I understand there is a debate over which to use, but that can of worms I don't want to open at this point!
