Mechanical Sending Unit Kits
Does the mechanical oil gauge require you to actually plumb oil lines into the cab?
yes.
about a 1/16" plastic line. be careful how you run it so it does not chafe on the hole in the firewall, a rubber grommet is a good idea.:D
yes.
So I guess my next question is why go through the trouble? If the existing wiring is bad you could just run a brand new wire directly from the sensor to the gauge. It would save you a lot of time and you wouldn't have the possibility of it rupturing.
I see it as a case of accuracy and dependability. Other than that it is just personal preference.:cool:
My oil gauge is mechanical and was on when I bought the used 83 CJ5 , I just ordered a mechanical kit for water temp and will make a report when I get it on.
I am looking for mechanical sending unit kits for both my oil pressure and temperature gauges. I currently have electrical sending units and neither are working. I figured that since I need to replace them I will go mechanical. What are you guys using and where did you get them? The jeep is a '84 CJ-7. Thanks.
when you get the oil gauge i would suggest getting the copper line its 15 bux more.....i had a plastic line bust:mad: not good, i didnt cut the new copper line. its really small and hard to cut, so i coiled it neatly under the dash. :chug:
