Misc Motor is skewed
Tech1129
Tacoma wa
78 cj7 amc 258 t18 Dana 20 Dana 30 amc 20 4.10 gears currently frame up rebuild
I am having an issue with the engine sitting in the frame on the mounts. The engine have a skew to it 1.25” measured by the side of the oil pan lip to the out side of frame. The measurement from the front of engine is 10.25” to the out side of frame at the back of the engine it’s 9” from engine to out side of frame the right side frame has the wide engine mount and the left the narrower one. Right side frame mount uses the out side holes the left side uses the forward 4 holes. Am I missing something? It looks like if I was to move the left mount back one set of hole the engine might site correct. Thank you for your input
I need pictures to understand what you are trying to say. Also is it a 4 banger 6 or 8????
Still need pics. Could have the motor mounts in the wrong location or completely the wrong mounts (what my issue was)
$210.00
  100.0%
